RDD6616U Cycle Processing Without Feed
Henry
I recently purchased a new machine equipped with the Ruida RDD6616U control system. Everything else is functioning normally, but when I attempt cycle machining, the feed does not engage. What could be causing this issue? How should I resolve it? Thank you in advance for your assistance!
Antworten (3)
  • Patrick
    Did you check the parameter settings and fill in the loop distance?
    • I changed the parameters and now it works normally
  • Have you checked the motor? If the motor doesn't rotate: the problem may lie in the motor itself (such as worn carbon brushes, burnt coils), the driver, or the control signal.
    If the motor rotates but cannot feed material: check whether the transmission components such as the coupling, belt, and gear are loose, slipping, or damaged.
    • All of these are fine, it's a problem with the loop parameters. It's now normal. Thank you
  • Check whether the feeding channel is blocked by residues, then inspect the mechanical components (rollers, belts, etc.) for any damage, and finally, check the sensor for any issues.
    • Thank you, it's normal now
