Akzeptierte AntwortHello, which version of RDWorks V8 software are you using? The RDC8445S controller only supports software version 8.01.68 for communication. Software below this version cannot communicate. You can log in to our official website: https://www.rdacs.com/en/download?type=software to download the latest RDWorks software for installation and communication. Thank you for your support!
Hello, Yesterday I discovered this myself through direct experience, after many other attempts and tests on different laptops. You were right — communication works only with RDWorks version 8.01.68 or newer. Thank you very much for the clarification and for your support. I would also like to ask you one more question: Does LightBurn work properly with the RDC8445S controller? If yes, is there a specific firmware version or configuration required? Thank you again. Best regards, Ghiță
Hello, since LightBurn is not our company's controller-compatible software, you can try to see if it can be matched, it has nothing to do with the firmware version of the controller, we suggest you use our company's compatible software RDWorks 8.01.68 for communication, thank you for your support!
Thank you!
