Akzeptierte AntwortHello, if it is a single head machine, go to the manufacturer parameters - system parameters, check the number of blades, and set it correctly to 1.
My CO2 laser cutting machine is equipped with a RDC6585G control system. I encountered a problem that I am at a loss for solutions. The machine moves along the frame normally, but there is no response when I press the start button. How can I check and fix this issue? Thank you in advance for your guidance
The bottom right corner of the main interface of the inspection panel should be set to offline mode
I guess you have closed all layers. Please check the layer parameters to see if they are indeed closed
It's normal now, thank you, Matthew
