RDC6585G controller set positioning point invalid
7760F7A1
I encountered an issue with setting invalid positioning points while using the RDC6585G controller for device debugging. When I tried to set the positioning point through the control panel, no matter how I adjusted the parameters, the system still couldn't respond correctly or save the positioning point. What is the reason for this? Thank you in advance for any suggestions.
  • B70F0980
    Have you set multiple positioning points? To set to “No”
    • I have made the correction, thank you
  • Confirm if the positioning points set on the controller interface are correct. Ensure that the coordinate values you input (X, Y, Z, etc.) are accurate and within the range of motion of the device.
