RDC6585G controller cutting head cannot be controlled
2C3A94E9
When debugging the RDC6585G controller, I found that the cutting head could not be controlled properly and there was no response no matter how it was operated. At the same time, the working indicator light of the height adjuster has not been flashing. After repeatedly checking the connection wires and settings, the problem still exists. I don't know what to do. Who can help me solve this problem? Thank you in advance.
  • Gary
    Check if the connection between the cutting head, height adjuster, and controller is loose or has poor contact. Ensure that all connecting wires are securely inserted, especially those related to the Z-axis or height adjuster.
  • Please check if there is a corresponding "follow", "calibrate" or "locate" status displayed on the system interface when attempting to control the cutting head. If the interface does not respond, the problem may lie in the communication or control commands themselves
