RDC6585G controller constantly touches the pressure limit switch when turned on
689EDFDD
When using the RDC6585G controller, the device always displays a collision warning with the pressure limit switch after each power on. Even if the power is turned off and restarted, the laser head continues to touch the limit switch and cannot reset normally. The controller seems unable to recognize the normal state of the limit switch, resulting in the inability to perform subsequent operations. Any suggestions?
  • Spark
    Check the status of the limit switch and check if there is any physical damage to the pressure limit switch, whether it is stuck by debris, has poor contact, or loose wiring.
    Manually trigger the test by manually pressing the lower limit switch, and then observe whether the corresponding limit signal changes on the diagnostic interface of the control system. If there is no change, it indicates that the switch or circuit is damaged.
    • thanks!
  • Check if the connection between the limit and the motherboard is normal.
