Akzeptierte AntwortThe system blowing signal to the solenoid valve requires the addition of a relay. You can try it out
I've encountered a new issue with my RDWelder-SW handheld welding system. I was in the middle of a job, and everything else was functioning normally, but I noticed that the shielding gas was not being supplied properly. What could be the reason for this?
Suggest checking the connection problem of the gas supply system, which may be caused by bent or blocked air pipes
Okay, I installed the relay and everything is normal now.
