How to solve the problem of eight point edge counting error in RDC6555G controller?
0DB765FD
My device is equipped with the RDC6555G control system, and I encountered a problem where the counting was incorrect during the eight o'clock edge patrol. Every time the edge patrol was performed, the system was supposed to perform edge positioning according to the preset eight measurement points, but during the operation, there was an inaccurate counting. How should I solve it? Any ideas?
  • 0055A4A1
    Check if the graphic file is not closed and if there are duplicate lines in the file. If there are, delete the duplicate lines
    • Thank you
  • Confirm software settings: Check if the path planning of the design software or controller you are using is correct, including path optimization settings.
    Confirm sensor settings: Ensure that the sensor parameters of the controller (such as origin alignment, zero calibration, etc.) have no deviation.
