Akzeptierte AntwortOnly supports FAT and FAT32 file formats, check if the file format of the USB drive is correct.
It's really frustrating. The controller equipped on my CO2 laser cutting machine is RDC6332NM. Everything else is fine, but after inserting a USB flash drive, it cannot be accessed. My USB flash drive is intact. I don't know what the reason is.
The controller's access function to large memory, such as 8GB and above USB drives, is not powerful enough. It is recommended to try using a small capacity USB drive
The target file should be placed in the root directory of the USB drive, but if there are too many root directory files, it may cause motherboard retrieval failure
You're right, thank you. I'm using it normally now
