During the processing of the RDC6563FG control system, the border exceeded the limit
Jamie
My device is in trouble again. The control system is RDC6563FG. Today, while executing a machining task, the "border out of bounds" alarm was triggered. How can I solve this problem?
  • roy
    I think your parameter settings are incorrect. The XY axis size does not match the actual size of the machine. Please set the XY size correctly.
    • I reset the XY format and eliminated the out of bounds phenomenon
  • Check if the set working area in the control system is sufficient to accommodate the entire machining path. If the set working area is too small, there may be a situation where the boundary is exceeded.
