When using Vcutworks for dual-head mutual shifting cutting projection, the prompt "border out of bounds" appears.
Amanda
When I use VCutWorks for dual-head mutual shifting cutting projection and perform full-format cutting on the calibration block, the program prompts a "border out of bounds" error. Is anyone familiar with VCutWorks? Any suggestions would be greatly appreciated.
  • The double head spacing of the format is less than the projection range. Please change the format settings
    • Okay,thanks
  • Please check your workpiece size settings, the sheet size is smaller than the actual required movement space for the tool path.
