Принятый ответDid you fill in the width and height of your projection screen inversely? Additionally, in the file parameters, the import file is set to 90 degrees
While I using VCutWorks for multi-projection point calibration with the alignment block, an issue occurred where the width and height orientation of the workpiece was incorrect. During the cutting process, the width and height of the work area were misaligned, causing the design to not match the actual material, affecting the cutting result. Any suggestions?
You can check if the width and height of the projection format are reversed
The reason is precisely that the rotation was set to 90 degrees when importing the file. Thank you for reminding me.
