Принятый ответHave you checked the collimating lens? Is it burned? Also, check the wiring
Just bought equipment, handheld laser welding, RDWelder-SW, I tried welding, but the welding effect was not normal. The welding process heats up quickly and the temperature control alarm is frequent. What is the reason for this? How should I adjust?
First, check if the red light offset is normal, and then inspect if the protective lens is damaged.
I think you should first check if the focusing lens has any smudges.
The collimating lens burned out, so I ordered a replacement online and am waiting for it to arrive.
