Принятый ответThe following situations may have caused the issue: too high filtering, not drawing the effective area, incorrect width and height of the contour, removing the black border, and trying to select the effective area with a box
My image quality is fine, but edge detection isn't working in RDVisionWorks. Which key parameters need adjustment? Thanks in advance for your help.
I think the edge detection parameters you set are incorrect, which led to this situation
After my investigation, it was found to be a filtering issue. It is now functioning normally. Thank you for your response
