RDC6442S laser cutting and pen marking offset issue
A86E1D1C
When using laser cutting, there is no size error. However, when using the pen marking function—for example, drawing a circle with a 4mm diameter—it only produces a circle of about 3.5mm. How can this issue be resolved?
Ответ (1)
  • You can compensate for the width by enabling the Sewing Width Compensation; function in the software layer parameters.
