How to set the pulse equivalent?
AC2CE701
How to set the pulse equivalent correctly? Thanks in advance
Ответ (1)
  • Hello, step distance is the pulse equivalent of the motor. When a pulse is sent to the motor, it corresponds to the absolute distance traveled by the motion axis. Before the value is set correctly, the machine can cut a smaller rectangle and automatically calculate the motor step length, which is the pulse equivalent, based on the length of the shape and the measured length.
    • Thank you for your response
