Gary
Принятый ответ
Принятый ответClick on Edit, select Set Cutting Point, double-click on the object to display all cutting points, double-click on the cutting point to select the desired direction and position
I have a simple question, how to set the cutting point in RDWorksV8? Thanks in advance!
What do you mean by cutting point? Could you give more details?
Okay
