How can I increase the length of U- Feed belt When cutting long rolls of material.
Gerhard
How can I increase the length of U- Feed belt or not to count the meters as I can only get about 4 full rotations of the U-feed belt when cutting long rolls of material. I then have to press reset every time before i can continue. On a RDC6685U-DFM
  • We do not need to count or distance to be true as we manual feed throuh the software or keypad. Pity we can't set the size to 0mm or have a function with manal feed, no count. the material roll normaly is longer than 30Meter.
  • Hello, you can increase the length of the U axis in the factory settings.
    • Hi Blue sea,I have done so. the max setting is 10 000mm. If i could set the belt length to 0mm will the manual feed still work? Unfortunately the factory revert back to 2mm.
      • blue sea
        Автор
        Hello, please check your manufacturer's parameter settings, has the U1 axis been reset?
