Zaakceptowana odpowiedźCan the camera be connected normally? Check the camera focal length, the clarity affected by exposure, and observe the image after adjusting the focal length
My CO2 vision cutting equipment is paired with the RDV6445G control system. During vision positioning, I've encountered instances where mark points are either misidentified or not recognized at all. After attempting parameter adjustments and re-capturing images, the issue persists. Could someone please help resolve this problem? I would be most grateful.
The actual position of the marked points may deviate from the preset position. Please confirm that the position of the marked points is consistent with the design drawings and try to avoid any deviation or incorrect positioning of the marked points.
After recalibration, the recognition is normal. Thank you
