Zaakceptowana odpowiedźI suggest you follow the following steps for troubleshooting, hoping it will be helpful to you:
1. Is the transmission of the associated motor encoder interfered with
2. Is the electronic gear ratio of the server set to correspond
3. Is the number of pulses consistent
4. Calculate whether the step distance is normal based on the lead and pulse count
5. Is the lead consistent with the actual hardware
The issue with the step distance has been resolved. Thank you, Caspar
