Zaakceptowana odpowiedźSomeone encountered the same problem as you before, you can refer to this post, hoping it will be helpful to you https://www.chanelink.com/community/question/rdv6563fg-net-connection-failure-via-ethernet-3889
Seek help! When I am using the RDC6563FG controller for Ethernet connection, the device still cannot establish normal communication with the computer. After booting up, the controller runs normally and there are no alarm prompts on the screen. However, after connecting to the computer through a network cable, the software still cannot search for the device's IP address. Despite multiple replacements of network cables and switch ports, the problem still persists.
My problem has been solved, thank you!
