Why can't the RDV6445G control system recognize the camera USB driver?
F619E49D
My CO2 vision cutting machine uses the RDV6445G controller. Today, when I was debugging, I found that the system could not recognize the device properly after connecting the camera through the USB interface. Subsequently, I attempted to plug and unplug the USB cable multiple times on the computer, and the interface indicator light lit up normally. However, the corresponding camera driver information was not displayed in the device management interface, and the camera image could not be called in the control system software. Who can tell me what I should do next?
  • Spark
    The driver is not installed properly, and the solution for USB cameras is to check the corresponding camera type and install the corresponding driver when installing the software for the MV SV MN MedMicro Vision model camera.
    • Thank you for your response
  • 1. Check the USB port and connection cable
    USB port: Confirm if the USB port is working properly and try replacing the port.
    USB cable: Check if the connection cable is damaged and try replacing the USB cable.
    2. Camera power supply issue
    If the camera requires additional power supply, ensure that the power connection is normal.
    • Thanks
