The feeding frequency of RDV6555G controller is not effective
I found that the set feeding frequency parameter did not take effect properly when using the RDV6555G control system for automatic feeding processing. Although the equipment can complete the processing task after startup, the feeding action is not executed according to the set number of times, and the actual feeding times are inconsistent with the parameter settings, resulting in material positioning deviation and affecting continuous processing efficiency and product consistency.
Thank you!
