RDWorksV8 defaults to cutting blue lines first
64E0A84B
I work with multiple colors in my designs, but RDWorksV8 consistently defaults to cutting the blue lines first on every file I import. This forces me to reset the order repeatedly. Is there a permanent master list or preference setting I can adjust, or is manual reordering my only option?
  • Adrian
    There's usually a list of stuff on the right of the screen. It'll have user/doc/move and all sorts of editable parameters, including the order of all colours/layers. Just change the number of a layer from 3 or 4 to 1, for instance.
    • thanks!
  • Every time you import a new file, RDWorksV8 regenerates layers according to its own set of rules and places the blue layer at the forefront, so you need to make repeated adjustments.
