Zaakceptowana odpowiedźI guess it's a template issue with you. The template angle is too low, so try increasing the template angle
When using RDVisionWorks for large-scale visual processing, I prepared to connect the device for matching, but the software still couldn't recognize the visual system. After clicking the matching button multiple times, the interface still did not detect the camera or controller device, resulting in the inability to complete the visual positioning setting. Any ideas? Thanks in advance!
An excessively high image resolution can result in excessive computation for the matching algorithm, leading to system lag or direct matching failure. It is recommended to try reducing the image resolution first.
Wrong selection of valid area number leads to mismatch.
You're right, I increased the angle of the template
