RDV6563FG-NET, A-axis reset failed, what should I do?
My control system is RDV6563FG-NET, and the A-axis reset failed. I don't know the reason, and someone told me it was a problem with the motor driver parameter settings. Do you have any ideas? Thank you all.
After replacing the limit switch, it is now functioning normally
