RDC6612U,Propose the inner contour when lifting the edge, what should I do?
706DAE24
My device uses the CO2 visual cutting control system RDC6612U. During the edge cutting operation, the system extracted the inner contour instead of the outer contour as originally set. The edge cutting should have followed the outer contour, but the system mistakenly selected the inner contour for extraction during the process. How should I handle this issue? I appreciate any suggestions.
Odpowiedzi (3)
  • Matthew
    The edge parameter is incorrect. The common edge mode has been selected
    • Thank you, it has been resolved
  • Adjust the edge threshold (increase, reduce internal recognition), set minimum contour filtering (area/length), perform binary or denoising on the image in advance, and manually delete internal contours if necessary
    • okay, thanks
  • Ensure sufficient clearance between inner and outer contours, and set the distance between different contours correctly. If the gap is too small, it may cause both the inner and outer contours to be lifted together.
