RDC6585G cutting pattern not closed
Liam
My newly purchased cutting machine is equipped with the RDC6585G control system. Today, I conducted a test and found that the cutting pattern is not closed. I don't know if this is a problem with the machine itself, the control system, or some parameter settings? Please help me, thank you!
  • Williams
    This issue is most likely caused by the following parameter settings. Please verify:
    1. Excessive starting speed
    2. Excessive idle speed
    3. Excessive cutting speed
    4. Cutting power not properly adjusted
    • Great, I've adjusted it and it's working fine now. Thanks!
  • This is most likely a problem with the parameter settings. Check the relevant parameters
    • Yes, it's a parameter setting issue. Thank you.
