RDC6585G controller set positioning point invalid
I encountered an issue with setting invalid positioning points while using the RDC6585G controller for device debugging. When I tried to set the positioning point through the control panel, no matter how I adjusted the parameters, the system still couldn't respond correctly or save the positioning point. What is the reason for this? Thank you in advance for any suggestions.
I have made the correction, thank you
