Laser marking of aluminum, insufficient depth
706DAE24
M1s controller, the picture is correct. MOPA laser is used to create relief on aluminum material. After trying for a long time, only the surface is affected. How to adjust the parameters?
Odpowiedź (1)
  • Enable Deep Engraving Mode. Use these as baseline settings for aluminum deep engraving. Always run a step test on scrap material and adjust accordingly.
    Pulse Width: 200–300 ns (Long)
    Frequency: 20–40 kHz (Low)
    Power: 80–100% (High)
    Speed: 200–500 mm/s (Low)
    Hatch Spacing: 0.02–0.03 mm (High density)
    Passes: 2–5 (Multiple passes recommended)
