I am using RDWorksV8 for machining, do not blow air
Noahe
I am a beginner and have just started working with RDWorksV8. Today, when I was operating the machining, it did not blow air and there was no signal output. What should I do? Thank you in advance for anyone's suggestions.
Odpowiedź (1)
  • Darren
    Suggest checking the following points:
    1. No fan enabled
    2. Relay wiring is incorrect
    3. Layer setting issue
    • I checked and found that the layer parameters were set to not blow air
