How to solve the problem of unclear slope effect in RDWorksV8 scanning mode?
64E0A84B
Excuse me, I have a new question. When using RDWorksV8, I found that the slope effect is not obvious in scanning mode. Originally, I should be able to see a clear slope transition effect during the carving process, but in actual operation, the slope effect is very weak and almost imperceptible. How should I adjust? Thank you all in advance.
  • Gary
    This is an issue with software slope parameters and scanning parameter settings. Modify the scanning gap and increase the maximum and minimum power (maximum power corresponds to slope bottom scanning parameters, minimum power corresponds to slope top parameters)
    • Okay, I've already solved it. Thank you
  • Is your scanning speed too fast? Excessively high scanning speeds directly impact the laser ablation effect. This prevents the laser from having sufficient time to engrave, resulting in an unclear gradient effect.
