How to solve the distance limit of the pop-up box after the RDV6445G controller's mark point recognition is completed?
C05D1BB6
Hello! I think I should look for more help in this community. During the operation of my CO2 visual cutting system RDV6445G, I identified mark points according to the predetermined process. However, after completing the marker point recognition, the system suddenly popped up a warning box indicating "distance limit". I think there must be something wrong, but I couldn't find a solution at once. Any suggestions would be greatly appreciated!
  • Adrian
    If there is a problem with the format setting or incorrect material placement parameters, check the manufacturer's parameters, format settings, and adjust the material placement position to increase the distance deviation before conducting a matching test.
    • The problem has been resolved, thank you
  • The reason for this issue should be that the working area you set in the RDV6445G controller does not match the actual processing area, resulting in the controller detecting marker points outside the valid range during marker point recognition.
