Zaakceptowana odpowiedźTry adjusting the focus to the appropriate position, increasing the laser power, adjusting the swing length and frequency, and see what happens
I use the RDWelderDW-V2Pro controller for welding operations. I thought the parameters had been set properly and the surface of the workpiece had been cleaned. After starting, the welding gun moved smoothly along the set trajectory. However, as the weld seam gradually appeared, I found that the effect was not ideal. There were obvious breakpoints in the middle of the weld seam, the connection of the molten pool was not continuous enough, and there was also a lot of laser splashing. Thank you in advance for any suggestions.
Possible cause of misalignment of laser focus: incorrect focus position leading to insufficient energy density → Adjust the laser focal length to ensure accurate focus on the weld seam position.
Okay, thank you. The welding effect is much better now
