CO2 Visual Cutting Control System RDV6445G Field of View Display Incorrect
A08E1C02
My CO2 laser cutting system is experiencing another issue. The RDV6445G's field of view display is incorrect. The image that should precisely show the cutting area is offset, making it impossible to accurately determine the cutting path and target zone. Any ideas?
Looking forward to your response,
Mason
  • 638AACF0
    The calibration range is incorrect, reading the width and height of the format, and only displaying the calibrated field of view for local calibration
    • Okay, thanks
  • The calibration range is set incorrectly, and the width and height of the format read by the system do not match the actual value, resulting in display limitations. Meanwhile, due to the use of local calibration, the interface only displays the calibrated field of view, and other processing areas cannot be displayed, requiring recalibration of the overall format.
