VCutWorks cannot project the graphic
Jamie
This is my first time using VCutWorks software. When projecting, the graphics won't display—it's really frustrating. Any suggestions?
Antwoorden (3)
  • Payson
    I suggest you check the following items:
    1. Check the projector parameter settings.
    2. Check the computer settings.
    3. Check if the projection installation method is correct.
    • It's a problem with the projection installation. Adjust the angle and everything is normal now. Thank you very much!
  • Have you tried restarting it? I believe restarting can solve many problems. Of course, this method may not be effective for you. You can check the parameter settings of the projector
    • I restarted, but it didn't solve my problem
  • Ensure that the correct .dxf or .gerber file format is opened in VCutWorksr, and that the graphics are displayed normally in the main interface of the software.
    • These are all normal
