The machine did not perform any operation for the visual function of the RDD6616U vibrating knife mark
Kevin
I am using the visual positioning (Mark point recognition) function of the RDD6616U vibration knife equipment. During the calibration or recognition process, the camera has successfully recognized the Mark point (or within the effective area), but the machine did not perform the expected alignment or cutting action subsequently. Who can help me? Thanks in advance.
Antwoorden (3)
  • Marshall
    Have you checked if jumbo frames are enabled in the network configuration
    3
    • After inspection, the giant frame was not enabled and is now normal. Thank you
  • Check if the camera driver is installed correctly
    • I feel that his network configuration hasn't enabled jumbo frames
      • You are right.
  • After loading the file, has the process of "visual positioning" or "scanning marker points" been executed?
    • I didn't enable jumbo frames before, but now it's normal. Thank you
