RDVisionWorks software installation error C++runtime library issue
E226C5F9
When I was installing RDVisionWorks software, the system popped up an installation failure prompt pointing to a C++runtime issue. Although the installation program could start normally, it was forcibly interrupted during the installation process. I reinstalled it several times, but the problem still persists. Where is the problem?
Antwoorden (2)
  • Howard
    If you have previously installed x86 programs, it may be due to antivirus software accidentally deleting system files. You can check if the vcredist_x86 program is stored in the software installation directory and click repair
    • Fixed, thank you for your response
  • RDVisionWorks must rely on x86 runtime libraries, some people only install x64
    • The antivirus software accidentally deleted it
