RDD6616 touch screen is not sensitive
Shane
My other device uses the Ruida control system, RDD6616U, But I found that the touch screen is not sensitive. I restarted it several times, but the problem still hasn't been solved. Please seek help, thank you!
Antwoorden (2)
  • Darren
    1. Access the menu on the panel - Touchscreen Calibration, then tap the crosshair cursor to calibrate;
    2. If the touchscreen is completely unresponsive and cannot access the menu, press and hold a blank area on the panel's main interface to force entry into the calibration screen for adjustment.
    • It has been corrected. Thank you for your reply
  • The touch screen should be kept clean, as oil stains, water spots, dust, and especially conductive metal dust can seriously interfere with the normal operation of capacitive touch screens.
