The computer system program installation is incomplete. Try copying and pasting the library to the software's root directory, or install the environment separately.
Hello everyone, I have a question to ask. After installing the RDCMarkVision edge patrol software, I prepared to start the software for visual positioning debugging, but after double clicking the program icon, I found that the software could not be opened properly. The system did not enter the main interface of the software, but instead popped up a prompt window showing that the relevant dynamic library files required for program operation are missing. What is the reason for this?
thank you
