Geaccepteerd antwoordDid you check if the polarity circuit of the foot switch is reversed?
My cutting machine uses the RDD6616U blade cutting control system. Yesterday, I reconnected some wires, and today it started automatically when turned on. However, I don't know which wires were connected incorrectly. I think this is the reason. Please seek help!
This situation is dangerous. Check if all emergency stop buttons are in the released state (popped up). If the emergency stop button is pressed, the system may not initialize properly, resulting in misoperation.
You're right, the polarity circuit was reversed, and after modifying the polarity wiring, it returned to normal. Thank you
