Geaccepteerd antwoordIf the "following error too large" alarm is frequently triggered during the cutting process, the maximum following error parameter should be increased.
My fiber laser cutting machine is equipped with the RDC6563FG-LITE control system. During operation, there is a significant tracking error in the cutting head and the focus position is inaccurate. Can someone help me? esteem it a favor!
Check if the Z-axis lifting mechanism (screw, guide rail, rack and pinion) under the cutting head is loose, worn, rusted or lacks lubrication, which is a common cause.
I increased this parameter, and the effect is much better
