Geaccepteerd antwoordI think your parameter settings are incorrect. The XY axis size does not match the actual size of the machine. Please set the XY size correctly.
My device is in trouble again. The control system is RDC6563FG. Today, while executing a machining task, the "border out of bounds" alarm was triggered. How can I solve this problem?
Check if the set working area in the control system is sufficient to accommodate the entire machining path. If the set working area is too small, there may be a situation where the boundary is exceeded.
I reset the XY format and eliminated the out of bounds phenomenon
