PROBLEMA DE INSTALACION
E54B9CE4
estoy instalando por primera vez una tarjeta RUIDA RDC8445S y tengo problemas ya que el administrador de dispositivoa la reconoce y le asigna un puerto com
pero al instalar el software no la reconoce ni por USB ni por Ethernet
Antwort (1)
  • Hello, you can check it according to the following methods:
    Cause analysis:
    ① Incorrect network IP settings.
    ② Not set correctly as a network connection method.
    ③ The motherboard and computer are not connected to the network cable or the network cable is faulty.
    ④ The motherboard and computer are not connected to the USB cable or the cable is faulty.
    ⑤ The USB driver was not installed correctly, or the communication method was not selected correctly.
    Solution:
    ① Please set the IP address of the motherboard correctly.
    ② Please set the connection method to network connection.
    ③ Please change the network cable to ensure that the network cable connection is normal.
    ④ Please replace the USB cable to ensure that the USB connection is normal.
    ⑤ Please install the USB driver correctly and set the connection method to USB connection.
